The reason for the question is that I read the following.
The SplitFire
Do I need an ignition Amp if using Splitfire Coilpacks?
From everything I've seen Ben, you only get the coil pack itself, and only in the royal blue colour too. I'm sure a competant auto electrician could provide a new loom if you need one Ben.
Where did you find the loom Ben? I need pictures.....you know, quality control and all that
