Look out for newage 17's with 225/45 RE070 Bridgestones already fitted. Great choice for track work. Will need rear arches rolling if they're not already.garetgax wrote: a spare set of alloys
Andy
Torx security by the description.Andy916 wrote:Gerry - can you tell me what tool is needed to remove the 99/00 MAF? It's a hex type head with a 'pip' in the middle so an ordinary hex key won't fit :roll:
garetgax wrote:ok so the plan is to get/install/replace the following prior to my next track day:-
Oil pressure gauge and sender
Water temp gauge and sender
Egt temp gauge and sender
triple gauge mount for centre consol to hold them all
Knock sensor- not sure where to put it yet but thats another issue)
New hybrid fmic core to replace the HKS one
Move the air filter into the inner wing( any idea's on whether i should look at removing one of the front fogs and having an inlet in the air filter if so how/which kit etc?)
Replace the current simota breather with a return to sump oil breather kit
going to look into the catflap sump but not sure if its a necessity and how much they are etc.
Any idea's/recomendations on the above will be more than welcome. Also interested in any info on the datalogic software etc. As being able to run E85 will also help with the temp issues etc.
Once everything is installed then Im going to not come in when it hits 105 but stay out and monitor everything to see if it goes up much beyond 105. Ive been reliably informed that oil pressure could be more if a concern above 105. But well see etc.
Im now booked for the sundays to quote gerry"chasing cones around an airfield" scoobysprint so I am trying to use the car as well
Yup. Is your Apexi already programmed to flash the CEL at a given knock level? Easy to do and gives you an immediate warning, whereas you're not going to be looking at hand commander knock display at the instant you get knock. But, get familiar with typical 'knock' level for your engine ie. the typical numbers on the commander which represent background mechanical noise not det.Gerry H wrote: You don't need water temp guage or Knock sendisplay. The Apexi commander will display both.
