lambda sensor gone (or wiring faulty)
overfueling as it cant make out what it is running at.
Scooby owners please help !!!!!!!!!!!
Gerry H wrote:More facts would be helpful. Under what conditions did it suddenly happen. was it while you were looking for a parking space at Tesco or on the eleventh run of the afternoon at the Pod?![]()
How have you reset the ecu? The green connectors or battery disconnect?
I'd be inclined to check level and condition of the coolant and oil for signs of one getting into the other.
All hoses for condition and that they're attached, check the intercooler hoses haven't split, look for splits in the air inlet hose and where it attaches to the turbo.
Remove all plugs, checking first that the leads are located and attached firmly. Compare colour, condition, wet/dryness, etc.
While plugs are out, perform a compression check.
HTH
