i think i have just done a sexwee, that is gorgeousstuartstaples wrote:
Something like this would be my choice
wide body 32
Hugh Janus
Hi Stu ...I had a serious issue with my external waste gate as it was too small . boost was set at 1.6bar and the boost creep went to 2.1 bar .
so I have bought another GT35r with a slightly bigger ex housing and a 44 mm w,gate is spot solid boost and holding properly.. will sell the other 35R as its in good form ..
we over bored it 1mm from sd and step 2 ported head with step 2 cams ..I will post up the spec of the engine when we are all done finaly getting there after being messed about by a tunner that i care not to be bothered to mention as its an iritation to me :x
will post up the results for all to see when she returns
cheers Gaz
cheers Gaz
Well update on the power run ..666 bhp and 580 flbs torque @ 1.6bar ...Im well happy with that ..
happy I went with the slightly bigger exhaust wheel now ...
went to 1.8 bar but no increace in bhp and only marginal torque so I will probably stay with 1.6 on full chat ..
will whack up the dyno sheet when I pic it up ..along with the engine spec to back it up too
cheers Gaz
cheers Gaz
George @ DCY
