Water Injection
sdminus
Post by sdminus »
dynamix wrote:
sdminus wrote:You will be able to lean right back with using water or what ever mix you like.
When you do this you will unlock hidden power in the engine.
You could un leash lots of power on a big spec car.
Scott
but i presume this would run the risk of melting pistons?
Only if your WI was interupted. The water is more effictive and enables you to lean out.
eg. I have to run 11.1 afr at 16 psi and that is on the toasty side
With water i can run back to 12.3 afr. I have had it as lean a 13.5 with water alone. the egts were up to 800 deg c at 8000 rpm. So all in all safe
Scott
ah - okay so we are back to the basic question about afr for power.
i get it ... i think .. ish
thanks Scott
Good thread this, I have learnt a lot.
Also learnt that I just slapped in my water injection and switch it on from time to time to lower intake temps. Didnt realise I could get a lot more out of it.
Yes Scott I will be trying the methanol/water soon bud lol
sdminus
Post by sdminus »
Please don not add methanol to your fuel tank tho....
It will destroy the pump and rot the rubber lines and o rings on the injectors. It will eat anything alu that it is in contact with for a prolonged time.
Nah mate, in the water injection tank !!!!
alexb
Post by alexb »
sdminus wrote:Please don not add methanol to your fuel tank tho....
Very important point this. There is a world of difference between using methanol in a WI kit and adding menthanol to the fuel...
