Subaru over fueling?
Under the dash there are two black plugs and two green plugs
One colour if you join them it checks the Ecu for fault codes
The other it clears the Ecu
The check one puts your fan on and off and boost solenoid relay
Google it and all will be revealed :)
Thats brilliant! Thanks for the link, I will give that a go in the morning.:)
I bought another boost soleniod along with the whole bracket and parts on, swapped it all over and its made absolutly no difference.:frown:
Clutching at straws now i wonder if it is down to the turbo???
Now maybe a random idea - what happens if you reset the ecu - connect the green to green connectors under the dash and fire it up.
Then disconnect them.
stockcar
Post by stockcar »
on a classic simply pop the battery off for 15mins and its reset............
I have not done that yet. I will give that a go in the morning if its not raining too hard? Thanks guys!:)
Although mine spends so much time off the road i take the battery off every time i park it up.
It really needs regular use by someone who will care for it :nod: You know keep it mint ;)
Stuart wrote:It really needs regular use by someone who will care for it :nod: You know keep it mint ;)
Subtle!;)
The more i think about it the more i am drawn to it being the turbo or rather the auctuator. It seems funny that this problem only started after the turbo was changed and has got worse since.
