My 2.0 corsa build
coilovers turned up yesterday fitted them last night, and booked in at autotest next week to get the camber and everything checked. My brother is a mechanic like myself works at a place called R&R Engines in beccles, so i took my block and crank to be checked and he couldnt believe how good they where for a car thats done a hard 145,000 miles
have ordered my piston rings, main bearings and big end bearings so will take some pics when they arrive!
yeah its getting there took the block to be blasted and acid dipped today, along with the rocker/cambelt/spark plug cover and inlet manifold. jobs for this week are order piston rings and big/main bearings and finish changing the valve stem oil seals and clean the valves and combustion chambers up.
shane
shane
