Be careful with Anti Lag !
gary@apt wrote:or you could turn als off with egt,we set rally cars to do this
also has a max time that it runs for before it turns off the timing retard and then just holds it on lower rpm limiit till you open throttle again,
done so if you crash with it turned on it doesnt keep running and every thing catches fire!!
It has those settings in the ecu - havent wired in EGT sensor to the ecu yet but a time limit would be a good idea. :D
gary@apt
Post by gary@apt »
you using drive by wire to jack throttle for als???
gary@apt wrote:you using drive by wire to jack throttle for als???
yep
dbw has its benefits sometimes :D
most of the time it is a pain in the arse but there are a couple of things that it absolutely excels at.
gary@apt
Post by gary@apt »
indeed im just about to retro fit it to mine
i need it for idle,als,downshift blip
so much easier than cable,
you got any pics of scooby one?
Erm not really any pics.
It is a very jerky stepper motor though.
