Cosworth Baffle Plate / Windage Tray - Review
I may have found the reason why the oil pressure suffered with this:
That is my oil pick up pipe and has a small crack in it that was probably sucking small amounts of air in and dropping oil pressure. Maybe the cosworth tray opens the gap up more hence why the difference in oil pressure for with and without...
Going to get the pipe fixed today and re-fit the Cosworth tray as this is a tested solution rather than welding up the sump.
