I know.cng1 wrote:I am in no way having a pop at APT.
Absolutely - but this is what makes wheel figures - wheel figures. It is the net of transmission loss power that actually propels the car in the real world which is where I prefer to drivecng1 wrote: Duncan, I see that you're local to me, happy to meet up and discuss rollers over a beer sometime. The problem that you're missing is that transmission losses differ in each gear. Adjusting RPM by gear ration gets you part way there but 4th is typically a straight though 1:1 gear so has substantially lower losses than 5th which is typically overdriven to say 0.8:1 - in 5th your transmission losses will be different but so will your tyre losses because your wheels are now spinning faster and thus are compressing a greater amount per engine revolution.
From my limited experience of coastdown losses on rollers I wouldnt like to comment on how they set it up.cng1 wrote: The trick to coast-downs is to balance the clamping load, on a double roller setup this is comparatively easy as you can tie the car such that you compress agains the rearmost roller on coastdown and against the foward one as it tries to climb out under acceleration. Yes there is a still a certain scope to get it wrong but it's not hard to get runs repeatable within 1% irrespective of which gear you run in or what you tweak the tyre pressures to be.
Personally I measure my modifications in the real world with in gear acceleration tests - cant argue with father time
