I'll get some pics when it's finished. Have to make some brackets first. I'm not suggesting it'll airlock bedause it's pumped, I just can't see it forcing all the air out, I reckon the top few rows will hold air.
The only way to tell, is to measure the temps when it's up and running.
Oil Cooler Fitment Questions
It's so b***** expensive to do that but the conssequences if something goes wrongdynamix wrote:Interesting points that JF raised about hoses Gerry
I know Steven Darley dropped a hose off his at Silverstone resulting in the fire and Maddog's oil cooler hose came off at the ring with worse consequences.
JF & AF are two people I take serious notice of. They don't take chances with the basics. I'll go and see what the locl hydraulics people can make up.
Gerry,
You can use the fittings/hose i supplied to get ferrules fitted on ok once you have sorted the pipe run lenghts if you want from a hudraulics company.
Hi Eddy, Sorry mate, that's my intention. I've just found a hydraulics company and I'll sort the run lengths and ask them to crimp the fittings. I also need to find some heat insulation because the Subaru oil filter nestles in the manifold pipes.
It's always the simple jobs that cause the most aggro. :roll:
Nice one Gerry,
Respect to make it a proper job mate. It is either right or wrong hey!
