How long do you guys run scoobys at trackdays?
- Mr Fletcher
logan
thanks for that info i had my suspicions something was amiss with the temp gauge not moving :roll:
i am pressuming the thing to do is run a pod where the clock is, with some gauges in. :?:
jason
jason
[SIGPIC] [/SIGPIC]
the reason the factory gauge is overdamped is for the masses otherwise they would have been bringing the cars back under warranty every time they cruised on the m/way.....................
as above if you want an accurate reading then you need an aftermarket set-up
- Bladerider
I think the general rule of thumb,
Is you can run them until the chocolate melts in the bores - or about a lap and a half of Cadwell !!!!
Seriously though, I wouldnt dream of doing a trackday in a car as notoriously weak as a Subaru without an oil cooler or temp gauge.
Sorry to be down, but its just so easy to break and so hard to save the money to fix.
J.
J.
I have issues !!!
