As title really. I've noticed that the truck constantly whistles when underload no matter what speed or what RPM. I've checked all the IC hoses and they're fine/tight. And the turbo + actuator is a year old. Question is, what could be causing this noise?
Boost whistle
Boost whistle
Morning
Thanks Stu
Think that might sort it.
Well I have already in the past had the hoses off and pressure + water tested them and they were okay. And this morning I did have everything apart again to grease pivot points, diaphragms and check the turbos actuator. While it was all off I did check the impellers movement and that's fine too. Was thinking that maybe there's an issue with the pressure release valve?
