Battery off with Power FC?
DJBB
Post by DJBB »
My 200 needs some welding doing to it, so the battery is going to have to be disconnected.
I'm running a Apexi Power FC, just checking that its not going to lose the map or die in any way if I do this??
You should be fine as long as you get the terminals the right way around when you hook it back up ;)
DJBB
Post by DJBB »
Cheers Stu!
See, this is the danger of forums :D I know fuck all about cars and even less about ECU's :thumbs:
Hope that helps :driving:
oh no stu what have you done, please dont tell me you have already disconnected your battery before performing the pfc safe map cycle
only kiddin :D
