Evo geometry
blacky
Post by blacky »
Gerry, on the Install manual for the Teins it says circa 340mm from wheel centre to arch.
Have search on the Tein UK website and download the superstreet manual as that will tell you, I would assume the heights should be similar for your BC's as the actual geometry of the struts should be the same.
I have print outs at home of my settings as well if required?
Shendy - seen your car on the ramps Saturday, doesn't look too far off now....been a while eh!
shendy
Post by shendy »
A WHILE!!!! bit of an understatment... very close now tho
blacky
Post by blacky »
shendy wrote:A WHILE!!!! bit of an understatment... very close now tho
Yes...Christian was telling me your tales of despair. Not good!
Gerry/Shendy - what spring rates did you go for on the BC's out of interest?
Tonynos
Post by Tonynos »
Phone AutoTest in Norwich and ask for Dave. He should be able to tell you what all the settings should be.
Tony.
shendy
Post by shendy »
blacky wrote:Yes...Christian was telling me your tales of despair. Not good!
Mmmmmmmmmmmmmmm been intresting:boxing_smiley:
Ive got no idea what the spring rate is
Crikey, You lot are being really helpful, thanks.
I'll take a look at the Tein site Logan and the geo settings would be great if poss.
Panic over thanks to Lee for measuring his heights. Mine are way out atm with low by 20mm or so at the rear and high at the front.
Thanks all. Great co-operation :D
