It has those settings in the ecu - havent wired in EGT sensor to the ecu yet but a time limit would be a good idea.gary@apt wrote:or you could turn als off with egt,we set rally cars to do this
also has a max time that it runs for before it turns off the timing retard and then just holds it on lower rpm limiit till you open throttle again,
done so if you crash with it turned on it doesnt keep running and every thing catches fire!!
