Ok boys and grills
Suz has continued the run of luck with a puncture in the sidewall of a brand new T1r caused by a thorn.
We have been advise it could be repaired but finding someone to do it is the issue.
A small patch on the inside should do the trick as its nowhere big enough to warrant a plug repair.
And plug repair cant be done on sidewall.
Any ideas guys?
Jay
Tyre repair?? urgent
blackskygtr
http://www.blackcircles.com/general/repair Doesnt look like it, a can of tyre weld might see you by tho.
- Mr Fletcher
225/45 16sidewaysfletch wrote:what size tyre is it jay
jason
And yes it was a strong thorn for it's size :evil: :evil:
May have sorted the problem, but only time will tell if it's a permanent fix, it's almost a pin prick so no real "damage". It was just letting a tiny amount of air, patch repair is possible but the cost may be a much as a new tyre unless I can find someone in the business
- Mr Fletcher
sorry suz i cannot help, the new tyre i have is 15"
jason
jason
[SIGPIC] [/SIGPIC]
