Underseal
roey
Underseal
Post by roey »
I've been told that now the cold and wet weather is upon us my Evo should be waxed or sealed underneath. Whats the best product and best way to do this?
LR6GSR
Post by LR6GSR »
roey
Yes i Japan they get no protection couple of years in the salt here the seams start to look rusty etc.
Take a look underneath some get done in the UK if you are lucky.
If not you have a couple of options seal it with spray on Shultz or use a waxoil product spray or brush on!
For best results i advise you remove the plastic arch linners and treat behind them up in the arches. Raliart dont bother there but worth doing.
Another common overlooked problem is the tin wear covering the filler neck pipe at the bottom it fills with mud and rots the pipe and covers.
Pop it of clean and treat put it back on. you can remove the fineck also to repaint it bit tricky to get to the clips and the screw in the filler flap always round off
Hope that helps if some one does it for you make sure you get a full job or you will only have part potection.
Liam
roey
Post by roey »
Thanks Liam had it serviced other week, they told me it had not been done so think I will have to get underneath it next weekend and do it.
Cheers
LR6GSR
Post by LR6GSR »
It is dity job but well worth the effort
Jet wash it 1st day before perhaps, then scotch brigh the suface and clean with thinners or simliar before aplication of you sealer.
I used waxoil i dont like seing the black tar scholtz sprayed every where but that is me. Waxoil does need topping up ever so often.
The boot floor is one of the worst spots so spend time under there.
Liam
323ian
Post by 323ian »
Liam did you paint it on?
Ian, also on R33's one place that is worth doing is the front inner turrets.
LR6GSR
Post by LR6GSR »
No i used the shultz type cans and sprayed with a compreser bought a Gallon of Waxoil and topped up the empty cheaper!
Then you can brush a little to :grin:
Liam
Andy916
Post by Andy916 »
My Scoob RA needs doing; anyone around here who'd do a real good job of it?
May have a go myself. Wouldn't it be better to steam clean first rather than jet washing?
Andy
