AVCR in use questions....
Just secured a second hand one and I am wondering a few things:
1) I understand that it targets in gear boost levels - how does it work out part throttle boost?
2) Does it really get the same boost in all gears? ie 2nd through to 5th ? or is there higher boost in the higher gears?
3) Is the solenoid activation smooth or can you feel jerkiness as the boost targets are hit and it opens the wastegate?
Can't answer the first two but there's no feel of jerkiness wih the AVC-R it's a good bit of kit.
Do you have all the info? Manuals are here:
http://www.apexi-usa.com/product_electr ... &pageNum=1
Just downloaded those Gerry. Thanks
Anyone know if this is the pin out diagram for an 06 STi ecu?
thanks gerry
