How long do you guys run scoobys at trackdays?
Last year it took me 2-3 laps to get the RE070's up to a good temp in the first time out which was damp. After that, they were on it at the end of one lap :)
logan
thanks for that info i had my suspicions something was amiss with the temp gauge not moving :roll:
i am pressuming the thing to do is run a pod where the clock is, with some gauges in. :?:
jason
stockcar
Post by stockcar »
the reason the factory gauge is overdamped is for the masses otherwise they would have been bringing the cars back under warranty every time they cruised on the m/way.....................
as above if you want an accurate reading then you need an aftermarket set-up
ASPerformance
MOTUL & MILLERS OILS,
online shop!!
or a PSI3 Monitor which can show several things at once.
http://www.psi3.co.uk
Bladerider
Post by Bladerider »
I think the general rule of thumb,
Is you can run them until the chocolate melts in the bores - or about a lap and a half of Cadwell !!!!
:D :D :D
Seriously though, I wouldnt dream of doing a trackday in a car as notoriously weak as a Subaru without an oil cooler or temp gauge.
Sorry to be down, but its just so easy to break and so hard to save the money to fix.
J.
