My 200sx
Posted: Wed Sep 13, 2006 11:33 am
Currently running it in after it's 3rd engine rebuild, should be finished by the end of the month (it better had be as I'm booked on a track day at Elvington on the 24th!)...
Chassis/Brakes:
8.5x18/9.5x18 Volk Racing LE37T Alloys
H&R Wheel Spacers (15mm front, 11mm rear)
Tein HA Suspension with Pillowball Top Mounts
Cusco Front Strut Brace
Cusco Rear Strut Brace
Cusco Adjustable Rear Upper Arms
Cusco Rear Toe Control Bars
Cusco Tension Rods
SPL-Parts Rear Traction Arms
Whiteline Anti-Roll Bars
Nismo Power Brace 2
Nismo Steering Rack Bushes
Nismo Diff Bushes
Solid Aluminium Rear Subframe Bushes
AP Racing 356mm 6-pots
R33 GTR Rear Disks and Brembo Calipers
Ferodo DS2500 Pads Front and Rear
Braided Brake Hoses
Transmission:
Modified Z32 Gearbox
Custom One Piece Prop
B&M Short Shifter
Nismo Gearbox Mount
ORC 709D Twin Plate Clutch
S15 Helical LSD
Interior/ECU:
SPA Charge Temp Gauge
SPA Gearbox Oil Temp Gauge
Defi EL Series Boost Gauge
Defi EL Series EGT Gauge
Defi EL Series Oil Temp Gauge
Defi EL Series Oil Pressure Gauge
Defi EL Series Fuel Pressure Gauge
GReddy A Pillar Twin Gauge Pod
GReddy Gearknob
Racelogic Traction Control
Sparco Pro2000 Seats
Bride FG Seat Rails
Sabelt Harnesses
Apexi Power FC D-Jetro
Apexi FC Commander
Apexi Boost Control Kit
Engine:
Balanced Bottom End with:
HKS Cylinder Liners
HKS 87mm Forged Pistons
Arrow Precision Engineering Con Rods
GReddy Sump
Modified Cylinder Head with:
GReddy 1.8mm Head Gasket
HKS 256 Step 2 Inlet Cam
HKS 264 Step 2 Exhaust Cam
GReddy Inlet and Exhaust Cam Pulleys (VVT Disabled)
HKS Valve Springs
Crower Titanium Retainers
Tomei RAS
K&N Air Filter
Apexi GT Spec Exhaust
Custom Frontpipe
Full-Race ProStock Exhaust Manifold
Tial 44mm External Wastegate
Hybrid HKS/Garrett GT3076R Turbo
Custom Turbo Dump Pipe
HKS Spec R Intercooler
HKS SSQV
Nismo Engine Mounts
ARC and Custom Catch Cans
GReddy Inlet Plenum
Custom 65mm Throttle Body
GReddy Oil Filter Relaction Kit
Koyo Radiator
Nismo Radiator Cap
Walbro 255 Fuel Pump
FSE Fuel Filter
SARD 850cc Injectors
SARD Fuel Pressure Regulator
Chassis/Brakes:
Cusco Tension Rods
Nismo Power Brace 2
Nismo Diff Bushes
Braided Brake Hoses
Transmission:
B&M Short Shifter
Nismo Gearbox Mount
S15 Helical LSD
Interior/ECU:
GReddy Gearknob
Bride FG Seat Rails
Sabelt Harnesses
Apexi FC Commander
Engine:
HKS Cylinder Liners
GReddy Sump
HKS Valve Springs
Tomei RAS
K&N Air Filter
Custom Frontpipe
HKS SSQV
Nismo Engine Mounts
GReddy Inlet Plenum
Koyo Radiator
Nismo Radiator Cap
FSE Fuel Filter
