My Honda Integra sprint car
Posted: Mon Sep 30, 2013 9:55 pm
Thought it was time t share my build thread. appreciate that those that know me will have seen my car anyway, but finally got around to updating a thread on a honda forum and decided i should copy some stuff across
First a short histort of my ownership. So started of with a standard black UK 1999 car.
Started the slippery slope with the following mods.
Full re-bush and spoon engine mounts
ditch the aircon
master cylinder brace
Dixcel front and rear brakes
Numerous track day tyres
Comptech Manifold, de-cat and Twinloop
BC racing coilovers
Baffled sump
H brace
Cobra Bucket and dished steering wheel
and a modest helping of this...
means happy owner. (before coilovers just in case you were thinking a lot of roll.)
Decided a second set of wheels is in order to run stickier tyres on events, and have a bit of tread for the rest of the UK weather.
I think a black and black colour scheme is emerging here.
Engine Bay not very exciting at the moment
The 2011 season started with a lightweight flywheel and new clutch, and as the gearbox needed a rebuild, a 4.9 final drive and US 4 and 5th gear were found to see if some lower ratios would help with the sprinting game.
During the down time a hondata ECU needed a new home, so i obliged and by the time the car was returned to me, it had a mace (well known honda bloke from the US) engine map to go with the new shorter gears. got a print out somewhere but its in the ball park of 170-175 at the wheels.
I have added a few more tweaks so far this year
bonnet pins
RMD racing battery
ABS binned and rear bias valve.
A few up to date pitures
Incidently im running in the new for 2011 modified roadgoing class, which allows most modifications, but basically limits you to full interior and no cage.
2012 Update.
I didn't drive the car much last year or compete, mainly as i was spending a lot of money on bits, and fingers crossed the car will live again next week
First and foremost, I'm not doing the work myself. Mark at Advance Evolution is putting the car together, and i stand around, contribute a bit and make lots of coffee. Its been an after hrs project so its taken a while and had a few hiccups along the way.
all photos are terrible and i will get better ones.
First off the new K20a motor - it did 14k miles in an EP3 before the previous owner strapped a huge turbo on and tried it out before being mapped. It has spent a lot of years sitting waiting for its intended purpose in life, and with new rings and a mild skim is good as new
after looking around at the gearbox options i found a guy selling brand new crate DC5 gearboxes at a very reasonable price so it made sense to spend a bit more rather than go for a second hand / recon box
A few shots of it in the car
ditch the aircon
BC racing coilovers
Baffled sump
H brace
bonnet pins
RMD racing battery
2012 Update.
