Page 1 of 14
VW Golf MKII 16v 3 door
Posted: Sat Jul 09, 2011 12:27 pm
by Ben
I thought i'd posted about my new toy, however can't find anything.
So, I've recently purchased a 1991 MKII 16v 3 door, spec is standard, rainbow interior, bbs RA's .. and it had a few minor cosmetic's that required replacement.
A little bit of history, this car belonged to me from 2002 through until about 2007 when I then sold it to by sister's boyfriend, who was promptly hit by a lorry damaging the passenger side, car was written off and then he bought it back and got another door ... well I can only assume it was from a rather 'fecked' up car ... but hey ho, exteriorly it looks fine.
This is how she looked by in 2002
Then I lowered it
Then she got shunted up the bum
However luckily it was only the bumper, rear panel and a minor dent in the rear floor :)
Car has covered 135000 miles and has a full service history. Not bad for
Posted: Sat Jul 09, 2011 1:02 pm
Nice car......will this be kept OE Ben? What do you suppose happened with the door then mate?
Posted: Sat Jul 09, 2011 2:09 pm
by Ben
Well when I removed the interior panel, chunks of it are missing !!!! .. plus it looks almost as though someone welded a panel into the door due to all the rough welds on the inside !! .. so I think it's mainly made of filler :) ... luckily amongst all the extra holes the originals still exist. The door was actually sourced from a scrappy as the original was beyond repair
Plan was to strip however now that i've sorted most of the interior bits it's actually really quite nice, it drives well, well except for a minor vibration when you hammer it - which i'm guessing will be cured by replacing the engine mounts and the subframe - if not then replace the drive shafts and it will be fine. Gear change is still actually quite direct but I will fit the one that Mike sold me (all metal components).
So in short, spend a few pennies to make it nice, get it removed from the Cat D list and run it until I have saved my pennies for my replacement :)
Posted: Sat Jul 09, 2011 2:33 pm
I didn't even know you could remove cars from a CAT D list? My fourteen month sabbatical has given me more energy (and cash) to have a bit of fun. I would highly recommend it if you are feeling jaundiced with things.......that and the lay off makes average cars feel bloody ballistic!!
Posted: Sat Jul 09, 2011 8:38 pm
by russ979
stuart wrote:I didn't even know you could remove cars from a CAT D list?
I expect Ben means he will have an independant inspection done? Although that wont remove it from the register. Unless Bens planning on an irish reg transfer?- But that would be a bit dis-honest and i sure not the way ben would go?;)
As im sure ive said before, im glad that the golf is back home again and knowing bens standards it will end up being quite a supurb example.:thumbs:
Posted: Sun Jul 10, 2011 9:49 am
by Ben
Yes Russ that was the plan, however I thought by having the inspection the car could be removed .. http://www.autoligninspections.co.uk/inspections.html
"The inspection procedure is designed to confirm both the identity of the vehicle and the quality of repairs carried out. Any vehicle that passes the inspection will be thoroughly roadworthy and within five working days the vehicle will be removed from the HPI condition alert register, you will receive a full written report of the vehicle and a Certificate of Conformity"
Posted: Mon Jul 11, 2011 6:49 pm
by Tk
looks nice ben, a standard 90 spec 16v , you dont see many of those around anymore
iv seen some awesome wheels for sale recently, i'l see if i can find a link
there zender sports splitrims with a perfect +25 offset mmmmmmmm
Posted: Mon Jul 11, 2011 7:20 pm
by RX7
Yeah Benny boy it looks good. Bit too standard though ;)
Posted: Wed Jul 13, 2011 9:55 pm
by martin
Thats crying out for the 20v T engine :)
Posted: Thu Jul 14, 2011 7:16 pm
He could just buy my Cupra and slot everything in to his minty mk2 :nod:
