The pocket rocket
Posted: Mon Feb 14, 2011 7:21 pm
So i took a gamble and brought the car off my cousin as a non runner, no mot or tax, water mixing with oil project
Spec is pretty much unknown but have found a few things:
Alloy header tank
ktec alloy carb top
mocal oil cooler
alloy degassing camber
ktec bored out turbo elbow
bigger alloy intercooler
samco silicone hoses everywhere
engine rebuilt back in 2006 new pistons+liners, bottom end rebuild
scorpion straight through exhaust system
clifford g5 alarm
Ecotek valve (removed as soon as i saw it)
This is how the car turned up on my door step after being towed,
Carb and turbo had both been removed and put in the footwell
then i started work on the engine to get the liner seals changed and inspect the rest for damage
Whilst waiting for parts to turn up from renault i decided to take the front bumper, front archs and side skirts.
Found a few medium size rusted through sections in the drivers outer sill and a small hole in the passenger side outer sill.
So far have cut out the rusted sections and put in new metal and welded it, seam sealed and painted with paint, got to do the rear of the drivers sill as the inner sill needs a bit of welding but need to drop the tank as its too close for my liking
Replaced both front wheel bearings and bottom ball joints as they were knackered
Then my bits from renault turned up
new heatshields as mine are missing
new headgasket kit
new rear window square trims as mine are falling apart
new sideskirt clips as most of mine have broke
Metre of brake servo hose as some knob has fitted a ecotek valve in mine
New coolant
Sump painted black by my brother
Alloy header tank
ktec alloy carb top
mocal oil cooler
clifford g5 alarm
new headgasket kit
New coolant
