I bought the car always with the intention of making it a track car so I wanted something with a full history and low mileage. I ended up buying this:
Only 63,000 miles and in great condition. It was an SMG car - that's a robotised automatic for those non-BMW boffins. I knew that SMG would not suit track work but, at the time, SMGs were very cheap and I got the feeling that they would have had a more cared for life than manual versions. SMGs are well known for failing so the idea was to convert the car to manual either when it failed, or beforehand if the track work required it.
I added Performance Friction two piece discs and Z rated pads:
img]http://i62.photobucket.com/albums/h101/ ... CN3064.jpg[/img]
Then sorted out a leak from the constant pressure valve and the vanos unit.
