My Shelsley T2 kit-car
Posted: Fri Apr 24, 2009 11:43 am
Hi, just joined.
Passed the SVA in November but still haven't got round to registering it as the engine blew during testing at Donnington! doh!
Anyway, here's a few pictures...
The engine/running gear is Rover T16 turbo from the 220 coupe but the rest of it is custom fabricated for the kit, chassis, suspension etc... weighs in at 850kg (wet)
On the old engine (pre big bang lots of smoke) - NB at the wheels:
172bhp at 5290rpm
197lb/ft at 3740rpm
10.4psi (limited) Boost at 3110 through to 6600rpm
AFR was circa 11.2-12 on boost
so, passed the SVA and down to Donnington to play with it - 6 laps in and oil smoke filled the engine bay - every oil seal popped
So, I've build the new engine and will be ready to go in early May, spec as follow:
1.9mm overbore to 86.4mm arias pistions
Pauter forged rods
2.5kg off the crank
6kg off the flywheel
Balanced
piper 270 cams + verniers
ported & flowed head
Ferriday Engineering thermal plates on the exhaust and inlet manifold
T3/T28 turbo
Seimens 660cc injectors
DTA ecu
Although not mapped yet (obviously!!) the target power is about 300lbft at 5500rpm so time will tell whether it makes it or not!!
172bhp at 5290rpm
197lb/ft at 3740rpm
Pauter forged rods
2.5kg off the crank
Balanced
T3/T28 turbo
DTA ecu
