Impreza FMIC and Manifold mods.
Posted: Fri Apr 10, 2009 4:22 pm
I did a little project thread so here goes.
A couple of things I've been wanting to do but it was too cold over the winter to be out in the elements as bravery and machoism disappeared with youth. So, a mate has moved his business to a unit 10 mins away and said I could use his ramp, that was 3 weeks ago and I'm still there :roll:
Jobs to do list:
1 Fit new Whiteline, rear anti-roll bar.
2. Remove ABS pump.
3. Rotate inlet manifold & shorten IC pipework.
5. Fit cold air box for inlet
6. Remove half a mile of clutch pipework.
7. Fit Fire extinguisher system.
8. Loads of other bits.
Anti roll bar was done but with complications. I went for uprated mounts which means replacing the OE brackets. After 13 years the bolts holding the o/s bracket were corroded in place and sheared. Drilling was only possible if I removerd the petrol filler pipe but as I had a full tank of petrol, we decided to weld the new bracket in place instead.
The ABS has been permanently un-plugged, electrically, since a very wet North Weald sprint last March. Braking at the end of a long, bumpy straight for a tight right ander would see me sail straight on until I released the brake pedal. The car has DCCD and applying torue towards the frnt meant that if one wheel locks, they all do. By the same token all wheels unlock with the ABS with a NO brake effect.
The space left by the ABS pump will allow a cold air box to be fitted in the inner wing, at long last.
The inlet rotating is aimed at reducing the tortuous route of the ic pipework with it
Jobs to do list:
2. Remove ABS pump.
