new bits for the mk2
evildave
Post by evildave »
finally sold the drum kit so spent all the proficts on the mk2;
alloy eccentric strut top mounts
in-situ adjustable rose jointed tca's
alloy group4 hubs + new bearings & studs
hubcentric wheel spacers 24mm
2metres of 3mm mudflap material
spent 8 hours fitting it all (apart from the flaps)
just need it seting up before rolling road on sunday.
hopefully the handling will be a lot better!
The 'before and after' with that little lot will be amazing :)
Who is going to do your setting up? I have a good contact near Norwich if that is any help Dave.
I have to say that I am looking forwards to seeing this in a week or so, there is just something about classic Fords.
antonioo
Post by antonioo »
nice parts :thumb:
mad dad
Post by mad dad »
not many corners on the rolling road :D :D looking forward to seeing the MK 2 used to have one with same bodykit etc only in white..........will see you there Dave,
evildave
Post by evildave »
stuart wrote:The 'before and after' with that little lot will be amazing :)
was going to use autotest in norwich for proper set up, will just have to be tracked by a local garage for now, until i can get it booked in.
