Subaru Impreza, New age Exhaust ONTO Classic LOTS OF PICS
Posted: Thu Jan 10, 2008 8:18 pm
I have been running with a decat down pipe, and blitz nur spec r system on my classic impreza for around a year ish now.
and 10 months ago, my 1st baby girl was born, so i started to look for a system that was quiter as the blitz is the next best thing to a drain pipe in a way of a silencer!
I have all ways wanted a titanium system, but the cost has all ways put me off. I use to look on ebay every few days for a new exhaust, and one day i noticed a decat sentre section and back box in FULL titanium! It was in new condition and from a shop. I placed my bit and kepted my fingers crossed and on xmas eve i won the auction.
Result i hear you say, but there was a small problem in my plan, and that was the exhaust was for a new age impreza and not a classic. I found out as much info as i could on the interweb about what the differences are, and i felt that it was worth a go.
Over the last couple of weeks, I have been planning and putting into pratice on what i needed to do.
this is the new titanium exhaust, it weights just under 5kg!!! for the centre section and back box!
From what i found out, the centre section was a little short (around 5cm) and on the back box, the centre hanger was on the wrong side. I also wanted to change it to a full 3" system
ok lets get started, the exhaust hanger
this is how it looked new
after using this
it ended up like this
but fuk me is this stuff hard to cut through, am very glad that i did not use a hack saw!!
Iam going to use a big exhaust clamp (mikalor) to go around the pipe, and from this go up to the standard mountion point with some ally bar or what evey i can find. but it is such a light exhaust i prob wont need it.
stage 2, the centre section.
this is the end that i need to cut off and make longer and into a 3" bore
the end result
i spoke to my dad vvvv nicely and he made this up for me, a 3"bore slip joint style to make the centre section the length that i needed and to make it 3" all the way through.
it is made out of brass, not the best meteral, but the only think my dad had in his workshop at work that was the right size.
more pics will follow as i hope to fit it this weekend, and fingers crossed it will fit fine
got the decat down pipe heat wrapted today with some Thermal Logic XTREME wrap, it was 2" wide by 50 foot. i have a small bit left over, and used stainless steel thick wire to hold it all in place
the rest of the system went up well. the back box was over to the right a small bit, so used stainless steel cable ties to ease it over abit.
the end result
could do with a clean
the bumper needs a small bit cut out above the tail pipe, and then it is finished.
it gives a really nice deep subaru sound. and it quiter than my old nur spec, all in all i am very happy how it has turned out and ended up with a light weight system, and that will keep the noise down the the boss
after using this
the end result
the end result
