Page 1 of 13
IWANT1's Drift Project!
Posted: Sat Oct 27, 2007 2:40 pm
by IWANT1
Not the normal start but it was cheap!!!!!!!
just got to sort a car now.........
Posted: Sat Oct 27, 2007 2:50 pm
by Bart
so you got the body kit before the car :?
so you have some idea what your thinking of getting then.
looks like a nice kit you have
Posted: Sat Oct 27, 2007 3:27 pm
by ants13
looks like an s-body kit
Posted: Sat Oct 27, 2007 3:56 pm
by IWANT1
Strange yes but too good an opuitunity to miss....
Took peoples advice and got my self an S13!!!! about 10mins ago :wink: :lol: :-D
Posted: Sat Oct 27, 2007 4:01 pm
by IWANT1
200SX RS13
The spec :
Footwork:
Apex 32 point adj. coilovers 9kg fr 6kg rr
Kazama adjustable castor rods
Kazama sub-frame locking collars
G-Corporation rear adj camber arms
Kazama D-spec tie rods
Kazama anti bump steer tie rod ends
Datmo steering column bush
Driftworks poly steering rack bushes
Cusco MZ 2 way differential
Cusco flyoff handbrake
Sparco steering wheel
Body:
Uras Monkey Magic bonnet vent, cut and rivet fit
Stitch welded
Fabricage 6 point EDC compliant roll cage
Kazama Crystal headlights
Engine:
1809cc CA18DET rebuilt 5k with new big end bearings, shells, oil pump, cambelt and wiseco forged pistons
Xs Power 4 branch manifold
XS power T25/T28 fitment dump pipe
Motoria full exhaust (front, de-cat, centre & rear)
HKS panel filter
H-Sport breather system
H-spec modified to secret recipe T25
Greddy Profec B spec 2 boost controller
Walbro fuel pump
Yashio Factory Okachan (water temp controller)
Gearbox:
Exedy slight uprate clutch
Nismo pivot bush
Nismo braided clutch line
Nismo uprated slave cylinder
Nismo gearbox mount
Wheels:
M2 hanbai 9 x 17 +20 drift wheels
15mm front bolt on hub centric spacers
Posted: Sat Oct 27, 2007 5:08 pm
by RX7
Pics Pics Pics !!!!!
Posted: Sat Oct 27, 2007 5:36 pm
by ESL
Nice one chap. Bring it over to St Ives so I can have a butchers.
Posted: Sat Oct 27, 2007 5:37 pm
by Tk
need to see the pics :-D
Posted: Sat Oct 27, 2007 6:06 pm
sounds awesome but
:needpics:
Posted: Sat Oct 27, 2007 9:41 pm
by 323ian
You sold the AX?
