Strange yes but too good an opuitunity to miss....
Took peoples advice and got my self an S13!!!! about 10mins ago :lol: :-D
Footwork:
Apex 32 point adj. coilovers 9kg fr 6kg rr
Kazama adjustable castor rods
Kazama sub-frame locking collars
G-Corporation rear adj camber arms
Kazama D-spec tie rods
Kazama anti bump steer tie rod ends
Datmo steering column bush
Driftworks poly steering rack bushes
Cusco MZ 2 way differential
Cusco flyoff handbrake
Sparco steering wheel
Body:
Uras Monkey Magic bonnet vent, cut and rivet fit
Stitch welded
Fabricage 6 point EDC compliant roll cage
Kazama Crystal headlights
Engine:
1809cc CA18DET rebuilt 5k with new big end bearings, shells, oil pump, cambelt and wiseco forged pistons
Xs Power 4 branch manifold
XS power T25/T28 fitment dump pipe
Motoria full exhaust (front, de-cat, centre & rear)
HKS panel filter
H-Sport breather system
H-spec modified to secret recipe T25
Greddy Profec B spec 2 boost controller
Walbro fuel pump
Yashio Factory Okachan (water temp controller)
Gearbox:
Exedy slight uprate clutch
Nismo pivot bush
Nismo braided clutch line
Nismo uprated slave cylinder
Nismo gearbox mount
Wheels:
M2 hanbai 9 x 17 +20 drift wheels
15mm front bolt on hub centric spacers
