the interior has been stripped and is permanent it weighs 1180 kg now still want to get carbon fibre/kevlar or glass fibre doors wings and bonnet and polycarb windows then it should be less than 1100kg
the engine is currently running 255 bhp should be 285-290 but its not holding boost
chip
-31 actuator
sytec fuel pump
k&n filter
mongoose exhaust turbo back
tarox discs
mintex pads
gaz coilovers
front and rear strut braces
it is booked into Supreme Car Services on 14 may for a turbo rebuild and to sort an oil leak and i will use them from now on for servicing
