Built 4k miles ago from Carwise UK
205 block [bored to .5]
Low comp pistons 7.2:1
Balanced crank, rods, and pistons
WRC head gasket
4x4 head with cleaned up ports
Ahmed spec inlet cam and standard exhaust
T4 turbo running 28psi
Grey injectors
Bosch 044 fuel pump
L8 ECU Live mapped my Ahmed Bayoo
Grp A coil, oil breather, baliey header and power steering tanks, turbo damper.
Forge RS500 intercooler
3" Mongoose system
Gearbox
Standard re-built T5 gear box and standard Diff
AP 6 paddle clutch.
Suspension
Koni Adjustables
Polly bushed
Grp A strut brace
Brakes
330mm AP 4 pots
4x4 vented rears
Braided Hoses
Interior
4x4 Leather Recaro's with black door cards, carpet, and early black 4x4 dash. RS500 gear knob.
Oil pressure, water temp, boost, voltage, and dual Act gauges
Exterior
Standard diamond white, 4x4 bonnet, late spec rear lights, clear front indicators and Morretts
5 Spoke Compomotive mo's 7.5"x17 in white.
Car goes for mapping either this Saturday or the week after.
Apexi AVC-R ready to fit.
Quaife ATB LSD, Adjustable TCA's, and Group A style rear beam all in pipe line after mapping.
[/img]http://
[/img]
