these seats certainly aren't easy to fit.....
well done frayz
mike-payne
Wow Frayz! I knew you were going for a carbon high sided seat, but I didn't know it was the one with the wrap around head support
Hardcore
I would imagine it would only be a matter of time before you add another, perhaps without the head support, to supplement the drivers side. Will have to watch this space I guess
_________________________________________
Once the engine is done, will you draw a line under modifications for a while?
Hardcore
Like to keep up my reputation for being a pervert Stu... this was the only seat that fitted the billstuart wrote:Wow Frayz! I knew you were going for a carbon high sided seat, but I didn't know it was the one with the wrap around head support![]()
Hardcore![]()
Something else ive been busy with...
Heres a quick snap of my new Bailey oil/separator. Different to any normal catch can as it is fully baffled and has a proper VTA and oil return.
There are 3 inlets at the top all -10AN in size. These are for the crankcase and one each for the rocker covers.
Then there are 2 x -12AN outlets at the bottom, one on the left will return to the oilpan via a banjo mounted on the drainplug. The outlet on the right will VTA via a secondary vapour can that will be mounted next to my battery. The secondary can i am yet to make but will feature a VTA filter, sight tube and drain plug.
Oh, i wanted a purposeful look as i dont do bling so i painted it wrinkle black (motorsport finish
Bet it ain't that simple internallydynamix wrote:Surely the oil will not drain to the sump with that set up frayz - it will follow the path of least resistance to the secondary catch can with the pressure going into the can ?
Read it again noob...dynamix wrote:Surely the oil will not drain to the sump with that set up frayz - it will follow the path of least resistance to the secondary catch can with the pressure going into the can ?
"Different to any normal catch can as it is fully baffled and has a proper VTA and oil return." :-D
Why is that funny?? lolblacky wrote:This is the funniest thing I have read :lol: :lol: :lol: :lol:frayz wrote: Oh, i wanted a purposeful look as i dont do bling so i painted it wrinkle black (motorsport finish)
Ps it looking good.
