Our new project/track car...
Glad its all sorted mate :-DSpec'C'57 wrote:yay its alive.... head gasket now changed and all running again... still need to sort the water pump, D/P to turbo is blowing also.. but it has moved using its own power today without half a litre of oil pouring out... :lol:
Defo sort the water pump out very soon as the T16 soon heat up dont want you to go damaging your engine
Was all running fine apart from a slight D/P blow and a few final touches before its test run out... so i have got to finally fit the air filter in position, the battery tray etc,
Sunday morning i move it on the drive for the work to be done. once jacked up and the battery tray etc firmly fitted i tight the exhaust up as well as remove the headlight as its pointing to the sky, once finished i connect the battery and all it does is NOTHING... :evil: Seems like there may be an earth fault somewhere. When you try to start it you either get a click from the starter or a power drain from the battery as all the dash lights dim... oh well best strip it down and check everything again...
