The whole system came out in about 3 minutes, 2x AN fittings, 1x bolt and 1x multiplug and the whole assembly lifts out for easy plug access. The drivers side is merly loosening one jubilee clip and removing the turbo intake.
Also managed to source a USB to serial adapter and could recaliberate teh Innovate wideband to read Gasoline. So with the wideband reading correctly and proper plugs. Shes all systems go for some proper boost.
Woohoo
