Toyota MR2
You know it mate
lots of people have fag breaks here like every 5 minutes, so instead of missing out, i'm having my 'make stuff' break, just all consolidated together
oh we have literally reels and reels of the stuff
i always cover the underside of my mouse in it too
yeah exactly, im always down in the workshop making bits and pieces out of scrap. if the tools and materials are there, then it's got to be done
what is the adapter for mate?
I've removed a Defi from the stock S15 a pillar pod. I want to fit my 52mm wideband lambda in there so I need a collar that fits in the 60mm defi hole which I can then fit the 52mm into. Make sense?Daniel wrote:oh we have literally reels and reels of the stuffi always cover the underside of my mouse in it too
yeah exactly, im always down in the workshop making bits and pieces out of scrap. if the tools and materials are there, then it's got to be donewhat is the adapter for mate?
well today has been a bit :/ the car was running fine this morning on the way to the BP garage so i could fill up for Sundays dyno day. filled the car up and after about 5 minutes the car has kind of lost a bit of power and the car sounds a hell of alot louder -sigh- so im hoping that whatever it is will sort itself out. Could it be down to fuel quality? i went from budget 95 to super 97. tempted to put the cheaper 95 in to blend the two just incase it is somethnig to do with the fuel. Either way i am still having the dyno run
couple of other things, changed the oil today as i thought it would be wise. plus i removed the aerial and blanked that off since i have never bothered listening to the radio :P
no not an excuse at all, it's actually annoying. there is heasitation from 4.5k up to redline and the extra noise is at 3k onwards. :/ just hope the scilencer isnt on its way out because it really does go loud. i'll take it for a quick blast tomorrow and see what it's like. but i have scoured the entire exhaust system and i cant find any leaks/holes/cracks. it's puzzling
