R33 gtst Show car
boxy
Post by boxy »
Well I said I was going to do something engine wise, so the time has come. Now have an engine sat at SPA waiting for me. Just have to pay for it now.
RB25DET Bored to 2.6L
Weseco Forged Pistons
Forged Con Rods
Tomei 1.5 Steel Head gasket
N1 Oil pump
Matched bottom end bearings
Tomei Poncam high lift cams
R32 balanced crankshaft with pully & crank collar
OS Giken used twin plate clutch (balanced with crank)
Tomei 1.5mm metal headgasket
used set Hydraulic lifters
tensioner (new)
idler (new)
cambelt (new)
water pump (new )
N1 main bearings
N1 conrod bearings
oil filter (new)
oil pump gasket (new)
cam shaft oil seals x 2 (new)
rear main oil seal (new)
clutch bolts (new) x 6
