Time to get it off whilst I am in the doing mood
First - up on jacks and off with the front wheels to allow access to the inner wheel arch liner. Then having marked a hole hrough the fog light ducts at the front I marked an outline for the exit pipe. Ok this isnt going to be direct onto the disc at this stage but it will blow in the general direction to aid cooling a little.
Then through with the 80mm air con ducting.
Then attach at the front:
