the inside is nearly done , cage is all welded in, box section welded in and seat mounted all harness hoops are in for the 5 point sabelts, still got to get most of the bloody dreaded sound proofing black stuff up, iv only cleared the areas that required welding but its getting there
wheels fit and clear the brakes which is a relief (and without spacers)
but i need to do a bit of arch work
i think i might need the wide arches sooner than later
a few other things have also been done like spray the drivers door ,its not fitted yet and the polycarb has been fitted in this one and am happy with it ( air vents on order for the windows )
stainless bonnet pins fitted
bailey alloy header tank fitted
all i need is a battery and it will be ok to use with the stock engine and hopefully will be used at the shakedown sprint at honnington on 1st march ( fingers crossed with the new engine and box :twisted: )
and a random pic with major front camber and unclean
