The black zinc came up real nice. Heres my pan with baffle in black zinc and gloss black powdercoated outer case
AVCS lines modified for turbo oil feed and modified water feed with AN fittings also in black zinc.
Lines all fitted up.
Cosworth windage tray and oil pickup fitted.
Then on goes the oil pan
Then new Apex engine mounts
With the AVCS lines finally fitted i could get the timing covers on, fit the sprockets and get her all timed up. Kevlar belts are damn tight but go on with a little push.
As i left it tonight, im waiting for an RCM belt guide to come through then the timing covers can go on. Hopefully get some more done tomorrow. But with the intake manifold rested on its starting to look quite smart and like an engine again
