Scoobyweb
Post by Scoobyweb »
Its not the dirt which is the problem it is the stones, If you remove the flaps your front doors and cills will take a hammering from road debris, you can't wash stone chips off :grin:
Your choice Frayz.
Chris.
i would keep them on the car seen some with them off and they just dont look right they suit the
car and as said as well as the dirt on the car its the stone chips that you will get up the side
of the car and as urs is black will show up more.
keep them on :-D
frayz
Post by frayz »
Okay guys ive taken heed,
Ive decided to order some brand new gloss black flaps. Although this time ive gone for the WRC spec "Kaylan" versions.
Not exactly cheap but much stronger and stiffer than the existing flapps,
OOOooh er mrs :D
Good decision frayz :thumb:
when I changed mine I thought it would be a good quick and easy job which it would have been if the nuts hadnt seized to the bolt on the front flaps and require cutting the bolt off :x
blacky
Post by blacky »
Frayz, can you not get prodrive Mini flaps like you can for the Classic?? I have copies of these, tehy look subtle but stop all the stones from chipping teh bottom of the doors etc.
Why not have that film fitted on the bottom of the doors instead? ...
When my car is resprayed I will have the film fitted over all the forward facing angles.
frayz
Post by frayz »
murano3 wrote:Why not have that film fitted on the bottom of the doors instead? ...
You mean armourfend mate, I could do that but..
A) Its damn expensive
B) I have graphics which would need removing and then replacing, which is also damn expensive
C) Its expensive :D
Did i mention its expensive???? :D
Ha ha, cheers anyways guys, ive ordered these new ones now anyway so they should be alot better.
Also bought an oil cooler today as i decided it was about time i got one.
Got a hyperflow one coming equiped with thermostatic sandwich plate and all aeroquip fittings
Obviously the TSL emblem will be the first to go :D
Are you getting excessive oil temps frayz?
dynamix wrote:Are you getting excessive oil temps frayz?
Who isn't?
Nice looking kit Frayz. Expensive?
Gerry H wrote: Who isn't?
me :D
