Niges MK2 Golf Track car build in 5 weeks.. MASSIVE Thread !
Nige
Post by Nige »
Thanks for the kind words guys...
Got loads done today, even though I didnt start until late Image
First job was to drill the extra hole in the baseplate for the Cage. I unbolted the existing feet-bolts, used a long bar to move the leg to the side and maganed to get a drill in the drill the plate.
Put the foot back, bolted it up properly and fabricated / welded some closure plates Image
Cut and welded to final part of the X for the door bars. Had to be careful to ensure there was enough clearance so I could still operate the window winder.
Cut off the old plates used for bolting the bar and then cut and profiled the bar that goes over the passengers head, linking the front and rear `hoops`
Repeated the Extra Bolt fitting, closure plate and X bar for the passenger side
Made some closure plates for the rear hoop feet too
Tomorrow I`ll give it all a light rub down with emery paper, then I can paint it. It will look a lot better once thats done Image
Jobs still to do (tomorrow hopefully !):
DONE Fab/fit bar over nearside seat linking front / rear hoops.
DONE Fab/fit remaining parts of door X bars
Clean/spray modified cage
remove dash, fit new speedo cable
whilst dash removed, fit new handbrake light as mine has stopped working
refit bucket seats
fit 2x6-point harnesses
degrease engine
refit undertray.
Much better - once that is painted that will look superb.
Nige
Post by Nige »
Yeah, once painted, they look LOADS better.
Looking good Nige. we'll be looking over your car to get some fabricating tips and picking your brains :grin:
Nige
Post by Nige »
Well, didnt quite go as plan today, ended up sidetracked on the exhaust AGAIN ! ImageImagemore on that later in the thread....
Job No1. Fit new speedo cable. Hmmm, dash removed but it is still fiddly to get my big hands in there. I needed someone with smaller hands, fortunately my ever willing helper Matthew was on hand to do it for me. He helped me ALL day Image
When I`d initially drilled the hole through the bulkhead for the gearchange cables, I`d consciously moved them to the nearside to try and miss the exhaust, I`d overdone it and the left hand cable was too tightly bent, which I think was causing the catching gearchange. I drilled another hole to the right and re-routed both cables. I then wrapped the cables with fibreglass matting to stop them chafing.
I then applied silicone sealant and kneaded it into the fibreglass to hold it all in place
The passenger footbrace was fouling the cables.
1 angle grinder later.Image
I then made an aluminium blanking plate and riveted it over the now redundant first hole. A quick spray and it looked pretty good.
Showing the gearlever and cable routing
Matthew rebolted it into place, being smaller definately helps
Next job was to fit the rear strut bar.
Drilled the holes in the tower
Bolted it up nice and tight, Matthew being outside and holding the nut in place made a hard job easy.Image
I`d trimmed the wheelarches in Germany last year, but I was still not 100% with them, there was still a `lip` as you can see
5 minutes and the tool of today (angle grinder) saw this.
A quick spray with some black paint to seal it and stop any rust.
A popular `mod` is to drill the airbox, however, this also increases noise and as I am trying to ensure I dont fall foul of the very strict limits at Bedford next week, I decided to cover some of them up.
Applied silicone around the holes.
I then cut a piece of plastic to fit and applied it over the holes.
Some gaffer tape held it all in place.
Found another part of the exhaust that was blowing
My first job done from the PIT, it made it SO much easier.
Split the exhaust
Clean with some sandpaper
Nice and clean Image
Some exhaust cement, new U clip (coated with copperslip grease)
Oh joy of joys. I thought I`d found the leaks, nope the weld was `dripping` moisture when the car was started.
Ground off the old weld
Then rewelded to ensure it was sealed
yaay, sealed.
start it up again, hmmm, whats that noise I can hear. Oh its the exhaust blowing AGAIN Image
This time, it was leaking from the downpipe, where it joined the manifold. I managed to get the welding torch up close enough to seal it which was NOT easily accessible. Pit the the rescue ! Fortunately is was only a small crack and I was able to seal it Image
1 SEALED exhaust later, yes thats right, NO LEAKS. ImageImageImage
I applied the heatwrap to the downpipe. I doubt I`d be able to do it from axle stands, but the Pit helped.
steveVR6
Post by steveVR6 »
I have the very same problem with the exhaust on my Golf. My next plan is to weld a piece of flexi pipe at the bottom of the manifold. Then if that doesn't work then i'll look to uprate the engine mounts(not cheap :o )
Is Bedford really that strict on noise for you to block the holes on the airbox?
I have a full Ashley system with manifold and modified air intake and was sound tested at Snetterton a couple of weeks ago at 92db.
Great reading the progress with the golf, keep it coming :wink:
Nige
Post by Nige »
steveVR6 wrote:I have the very same problem with the exhaust on my Golf. My next plan is to weld a piece of flexi pipe at the bottom of the manifold.
I have a flexi piece already, I`m certain it works too, I think I cracked the manifold (again) when I was removing the system last week, it was very stiff and my manhandling probably caused the crack.
Bedford are incredibly strict, 87.5dB drive by, ONE fail and thats it, day over and you go home, NO second chances. Thats why I took the extra precaution of covering the airbox extra holes, it simply isnt worth the risk IMO. I`ll take them off afterwards, ready for the Ring, but for Bedford, I`d rather be safe than sorry.
IWANT1
Post by IWANT1 »
Great step by step project :wink:
A little tip bin the exhaust paste its crap stuff, use silicone you may think its crazy but try it next time you will be surprised how well it works been using it on exhausts for years :thumb:
87.5db is whisper quiet :o
Good progress Nigel
wouldnt gaffer tape have done the job on the air box on its own?
Nige
Post by Nige »
After being told that trimming the wheelarches was a bad idea, I took steps to remedy it this evening with some `plug welding` Image
Take one rear wheel arch
Remove the cover
Drill hole in OUTER skin only.
remove paint around hole
Start welding from the CENTRE of the hole Image
Ending up with a plug weld, securing the inner arch to the outer.
Repeat by drilling lots more holes
Plug weld those holes
Check good penetration by the welds ALMOST burning through the inner panel
Grind of the `proud` part of the welds
Smooth the arch
At this point, you would fill and smooth the arch, then spray as normal. As this is a track car, I didnt fill it, just primer and topcoat.
Liberally coat the inside and edge with underseal
Reapply the arch
One weakened arch restrengthened in an hour Image
I`ll be doing the other side tomorrow evening.
