so...
Baffled sump is fully in place, I had to make some minor modification to the oil pick up pipe rear stay to enable it to fit with the sump baffle without fouling but a good excuse to use the dremel to do it. It is also a lot easier to refit the baffle plate with this mod so I didnt need 3 hands this time. Sump went back on and dropped the engine down to bolt the mounts in place. This should be an improvement.
Headers and up-pipe were removed as part of this job and also to rewrap them. Lucky I did this as it showed that the 3 bolt up-pipe gasket had split into 3 parts and was not sealing the exhaust. Looks like it has been like this for ages so it would have been costing spool up and power.
I got some fresh new exhaust wrap and a new gasket from Lateral and re-wrapped the headers/up-pipe as the old stuff was hanging off.
I fitted these back on last night.
Also done:
- re-routed the MAP sensor take off to a central position to give smoother boost control. It was taking off from the FPR vacuum take off.
- re-routed the cylinder head breather pipes
- regreased ARB bushes
- properly fitted the towing eye
- tidied the induction kit pipework to reduce pushing out of wheel arch liner. This has reduced but i still need to make some proper wheel arch liners that fit with the new wider wings.
The need to do list for round 1 is looking very small now
and should be finished on friday/saturday leaving next week to clean the car, bleed the brakes again and do a couple of nice to do bits.
