EVO 8 APT mapped
Good to hear you're pleased with the progress Tony :thumbs:
Harry
Post by Harry »
Tony that looks really nice
Tonynos
Post by Tonynos »
Tk wrote::thumbs: glad you got your confidence back in the car tony
i use bc's on the pulsar and i cant fault them i actually prefer them to the fully adjustable teins i had (on a different pulsar and the sti) i found the bc's had more adjustment etc.. i guess it could be down to spring rates or something i dont know
we are all different :D
I'm not sure if the problem with the BC's was to do with the way they were set up. With them being the inverted type they should have been adjusted for height on the bottom rather than the spring. The guy at Autotest who did the alignment didn't know that and adjusted them on the spring so probably buggered the preload setting on the springs.
Tony.
Tonynos
Post by Tonynos »
Harry wrote:Tony that looks really nice
Cheers Harry
Tony.
Glad you ve got the suspension sorted Tony!:thumbs: although should nt you be out at sea?
looking good Tony:thumbs:
Tonynos
Post by Tonynos »
russ979 wrote:Glad you ve got the suspension sorted Tony!:thumbs: although should nt you be out at sea?
I've forgotten what the sea looks like :( been off since middle of Feb and still no closer to getting back to work. Brain scan next if they can find :D
Tony.
Tonynos
Post by Tonynos »
Mr Fletcher wrote:looking good Tony:thumbs:
Cheers Jason
Tony.
blacky
Post by blacky »
Hows the XP8's???
Tonynos
Post by Tonynos »
blacky wrote:Hows the XP8's???
Really really good. There's feel in the brake pedal now and they work so much better than the Blue Stuff. Gary had a few problems setting them up as they started binding after getting them hot, but once he re-shimmed the calipers they were spot on.
Tony.
