My RS Turbo - Plenum project (+ MORE!)
ants13
Post by ants13 »
looks awesome Christian.
Any chance you could make a similar thing for my s13 ? :D
kev@tga
Post by kev@tga »
good work mate looks a proffesional (sp) job cant wait to see it on the dyno or even the track :lol: :-D
Christian and Beccy
Post by Christian and Beccy »
Hey, look what I found.....
It's a rather nice looking Plenum. Hmmmmm, bummer, it's not for an RST. :(
Christian and Beccy
What is this I see??......
:eek: :eek: :eek:
Christian and Beccy
So, lets not waste any time......
:twisted: :twisted: :twisted:
Christian and Beccy
Had a l'il bit of machining done.....
Alloy flange (thanks to Mattie).....
Alloy reducing sleeves to go from the large trumpets in the Plenum to the port size/shape of the RST one.......
Watch this space. :grin:
Christian and Beccy
Thanks again to Mattie for sorting the welding out. They actually made a heavy steel brace to bolt the flange to before welding it, to hold it all in place and try and limit distortion. They did well, they didn't even re-machine the flange as it hardly went out of shape and any deviation that it does have certainly pulls true when its bolted down. We'll see how it goes, I can still get it machined if need be.
Then after stripping all the other Plenum off, I tried the new one on for size!! I had been shitting it about the Throttle body fouling the Brake Servo. Seems I was right, so had to have a rethink. :?: :?: :?:
So, once I knew in my mind where I was heading, I set about cutting the Plenum around further and had a piece made to mount the Throttle body onto. Here it is all welded into place. I just need to drill the mounting holes for the TB now and tidy it all up. Then, as I said above, get the other few odds and ends done. One of piece of good news from the test fit is that it looks like I can make the connection to the current Intercooler with bits that I already have, I just need one 60mm Silicone hose, which is no great drama. I didn't want to hack my cooler around as the plan is to get another one, so mine will be sold. I am going to add a couple more Vacuum take-offs next to the others on there, then I can get rid of the Vacuum Manifold seen in the top pic. That little thing has been handy, but now I have the scope to add as many take-offs as needed, I might aswell keep it as tidy as possible. They are underneath too, out of the way!!
Oh, need to finish the porting of it too. I want it all to match nicely, which it almost does with the work I have done already. :top:
What do you think? ;)
I need to find out about Throttle Cable lengths too. Ideally, I need a Throttle Cable the same as the RST one, but slightly longer. The RST one does reach, but not as comfortably as I would like. I wonder what the XR3i one is like?
Christian and Beccy
Got my new injectors.......
Siemens 610cc jobbies. Mine were getting close to their limit, so opted for these for a little more headroom. The Plenum was also a little tight for space, so the slim design of these will certainly help with that. (I have a couple of sets of these spare if anyone is looking for high impedance top-feed injectors, let me know!!)
I have since managed to get the rest of the porting done andthe fuel rail is mounted. I wish there was a decent Alloy rail on the market that would suit this application, athough that isn't a major problem. ;)
Christian and Beccy
Woooooo!! I've had another delivery. Wasn't expecting these for at least another 1-2 weeks yet. Big up Gaz for turning my order around so quickly. Spangly new Gaz Gold's. These usually retail for around
Ian200sx
Post by Ian200sx »
great work :-D
whats the Plenum off?
mk1 escort, supercharged.
