Project Rex
Well it runs!
Ran it up to temp and checked for leaks. Seemed to be ok apart from a few drips of water which I think is the overflow tank.
Couple of issues though. Sounds like the downpipe is blowing. I used new gaskets but maybe the bolts need to be re tightened. Also sheared a 10mm bolt on the throttle body elbow.
To be honest though I'm just glad it runs at all! Those issues should be sortable before mapping.
E46 M3 track day car
Well done mate, one heck of a job and you should be proud of yourself for taking it on. Apart from taking the engine out I dont think there is a harder job!
Blow should be sortable, I think you might have to keep it off boost as well if the blow is bad.
I might have a spare bolt you can use for the shared one you have.
As much as I think you're a massive mincer for not going single turboGedge wrote:Easier isn't always better![]()
I love the response of the twin setup, and with a second turbo that actually has blades (!) and isn't leaking oil, it's going to be monstrous!
