'91 r32 gtr
- Monster
Have you looked at xxr wheels? cheap as chips. I was going to get them for mine having had the rota grid drifts on my last car i wanted something different. Ended up going for a different style of rota in the end. Rota's are pretty good value and looks wise I reckon they look as JDM as many jdm rims. Pics of xxr and rota on my build thread.
Why don't you like the tein suspension are you having problems with it? I've never run tein and heard mixed reviews, some people love it, others not so keen.
I've had Teins before and found them spot on (cue memories of hooning after bikes on open country roads in my RX7 heh) but since fitting these to the skyline they were horrible.
When I bought them they were already set for a decent height so fitted them as they were which I think is what the problem is with them to be honest. Done the rears so far as I had them apart for the hicas delete and they had so much preload on the spring i'm hoping that reducing this will solve my problem
Got the fronts to do yet but gearbox/clutch/whatevers-broken needs sorting first which I'm removing this weekend
So got the gearbox off - expecting to see something very obviously amiss with the clutch engagement setup but nothing looked out of place at all
Replaced the pivot ball with the nismo item I had, replaced the release bearing with the new one I had and now a bit unsure what to do... clutch has a few hot spots and a bit of a lip on it but have been told by SPEC that its all normal and nothing looks amiss...
Unsure what to do now as if I put it all back together now i've not replaced anything which looked like it might've caused the problems with not being able to disengage the clutch.
Clutch fork doesnt look bent at all, no leaks from the hydraulic system and the servo was pushing on the fork when the clutch was pressed prior to removal...
Opinions greatly appreciated
not sure this will help - but there are some differences between the years.
Full detail on BNR32’s.
Production Figures 43,934 vehicles.
Standard 40,390
NISMO 560
V-spec 1,453
V-specII 1,303
N1 version 228
Chassis Numbers
GT-R NISMO (sold 500) : BNR32-100000 - BNR32-100560
Version 1: 21/08/1999- : BNR32-000051 - BNR32-017466 (Note this model has no side impact bars)
Version 2: 20/08/1991- : BNR32-212001 -
Version 3: 01/01/1993- : BNR32-300001 - BNR32-314649
Annual Production 1989: 4,555
1990: 8,426
1991: 7,081
1992: 7,961
1993: 6,204
1994: 7,465
Body Colours
Version 1
- Gun Grey Metallic (KH2)
- Jet Silver Metallic (KG1)
- Dark Blue Pearl (TH1)
- Red Pearl Metallic (AH3) (Wine red!)
- Black Pearl Metallic (732)
Version 2 / Version 3
- Cristal White (326)
- Spark Silver Metallic (KL0)
Version 1 Released: 21th August 1989
Produced to make victory at Group A race.
Length: 4,545mm x Width: 1,755mm x Height: 1,340mm
Wheelbase: 2,615mm
Curb Weight: 1,430kg
Max Power: 280ps/6,800rpm
Max Torque: 36.0kg-m/4,400rpm
Engine: RB26DETT
Displacement: 2,568cc
* Twin ceramic blade turbochargers.
* Electrically controled torque split four wheel drive (ATTESA E-TS).
* 4 wheels multi-link suspensions.
* 225/50-16 tyres.
NISMO Released: 11th March 1990
Produced 560 BNR32 GTR Nismo as Group A evolution model. (Only 500 were sold)
* Metal blade turbochargers.
* Additional air intake on the front bumper.
* Bonnet hood top spoiler
* Bigger side sill protector.
* Rear auxiliary small rear spoiler.
* Less rear wiper.
* Less ABS.
* Less air-con.
* Less intercooler net.
* Curb Weight: 1,400kg (weight reduction by 30kgs.)
Version 2 Released: 20th August 1991
* Side impact door beam.
* Factory optional driver side airbag.
* Seatbelt warning indicator.
* Shock absorb steering wheel pad.
* Fireproofed interior materials.
* Revised headlight lense and H1 type headlight bulb.
* Curb weight: 1,480kg (50kgs increased.)
Version 3 Released: 3rd February
* Pull type clutch.
* Revised rear diff cover. (1994 onwards.)
V-spec Released: 3rd February 1993
Anniversary model for 3 years champion of Group A race.
* Height: 1,355mm (+15mm)
* Brembo brake calipers and discs.
* BBS aluminium wheels.
* 225/50-17 tyres.
* Curb weight: 1,500kg (20kgs increased.)
V-spec II Released: 14th February 1994
*Anniversary model for 4 years champion of Group A race.
*245/45-17 tyres.
*V-specII Sticker.
N1 version Base car for N1 Taikyu Championship Series. (Group N endurance race equivalent.)
* Less rear wiper.
* Less ABS.
* Less air-con.
* Brake cooling air guide.
* Non projector headlights.
* Metal blade turbochargers. (V-spec N1 and V-spec II N1.)
Standard 40,390
NISMO 560
V-spec 1,453
V-specII 1,303
N1 version 228
Chassis Numbers
1990: 8,426
1991: 7,081
1992: 7,961
1993: 6,204
1994: 7,465
Body Colours
Version 1
Wheelbase: 2,615mm
Engine: RB26DETT
* 225/50-16 tyres.
* Less rear wiper.
* Less ABS.
* Less air-con.
* Pull type clutch.
* 225/50-17 tyres.
*245/45-17 tyres.
*V-specII Sticker.
* Less rear wiper.
* Less ABS.
* Less air-con.
The release bearing in your picture 30502-21000 isn't listed as being for an R32GTR also you have a twin now so would need a different bearing. Just had a quick search on the net and it seems to be for a twin you need Nissan 30502-14601.
some info here - http://www.exedy-racing.com/racing/en/pro/repair.html
Have you checked the clutch manufacturers website?.
Thanks for your help Ben - could change gear no problems with the car switched off but not with it switched on (likewise if was in gear the clutch did nothing)...
Up until these problems though it was working fine, did a couple of launches no problems and then when it let go suddenly it was when I was driving relatively gently (although before it let go it was crunching a little between gear changes).
As per your link (http://www.exedy-racing.com/racing/en/pro/repair.html) the release bearing I've got is the oem nissan one for an R32 GTR - this was the same as my old one which worked with the clutch previously (and came from a Exedy Stg 1 clutch kit iirc) although the fingers on the spec clutch pressure plate are very different to the ones on the exedy kit;
Release bearing (30502-21000)
Spec pressure plate;
Exedy pressure plate;
Such a tricky situation but very tempting to pick up a second hand OS Giken twin plate from somewhere (one on DW for
