My AE86
Sweeps
Have you got a paint code for that yellow?
Looking sweet!
Had a day off today so made a bit of progress and found some problems ...
Fidanza 212mm Flywheel and Helix clutch..
Inlet manifold fitted and water pipes etc
What happened next...
She's in
Need to shift the washer bottle before it dribbles down the inner wing as a blob of plastic ... Plus the wiring will have to be re-rooted, in-car all being well and bring it out further to the drivers side
Plenty of room at the front, even with a electric fan there should be enough room to V-mount but can't afford an intercooler to suit... A mod i will consider later..
Lots of flywheel showing :shock:
Last but not least i need to make the hole for the gear stick it little bit longer, but that won't take long..
I need to drop the gearbox out again to put a plate in the gap, i assumed it wasn't required as we never used to bother on fords, but apparently it needs to be there.. Not to worry, give me something to do in the morning... :?
She's in
BDC for the win !
That is coming along very nicely.
Quality parts and quality work. Well done mate.
If you need any hoses, connectors or an intercooler give me a shout
