95 WRX Type RA
Some progress is better than none at all mate
Not booked anything yet as I'm not sure about work shifts as I now have to work some Sundaysruss979 wrote:That wheel looks the mutts... without the carbon centre.
Have you booked your first sprint round yet?
If car is done and no work il late book north Weald for the 17th
Rear tow hook fitted
Fitted some mk1 golf door trim around the hole I cut out with mikes plasma cutter
Works a treat
Let me know if you want any mike and il bring some over I have loads of it
And I ditched the forge dump valve in favour of the standard recirc bit this needs a rethink as its not working, sounds like there is no valve atall with air cutting on the turbo vanes
Sounds good but need to sort this
I assume I need the valve closer to the pipework
Next instalment will be brakes when I get time
Works a treat
Good work
Bit of a long shot but have you sold the AMG rims off of your T4?
Beyond repair then? May have been OK for the Vito
Hang on to them for me Trev, that would be great
